It is currently Thu Jul 24, 2025 11:54 am
PostPosted: Mon May 14, 2007 6:35 am
I had a couple questions ..
I made my own thickness sander and through the true-ing up process of the mdf {and bb ended} drum there were some minor inconsistancies... which led me to a diagnose a couple component problems in the machine that Im reworking now..
I was orginally going to leave the drum bare wood -
but Ive since decided to finish it as per the directions of the ShopNotes article seeing as I bought some polyurethane wood finish.
I looked through the multitude of finishes at the hardware store and settled on polyurethane because it said on the label
"bowling alley tough" &
"for gymmnasium floors" etc
things like that - you know > strong like bull.
The directions in the SN article just said put a couple coats of finish on it, without being too specific...
Ive never used polyurethane lacquer for anything other than sealing the ends and open faces of wood I was curing - can anyone see any problems using it for this drum application...????
It seemed proper for the application because of its stated "toughness"
now I always go by the maxim "its not what you dont know, that fouls you up - its what you dont know you dont know"
so Id thought I would ask, having very little experience finishing things...
I forget what my second question was - Il tack it on once I remember..
Charliewood
PostPosted: Mon May 14, 2007 6:49 am
I dunno if Ive posted any pics of it - this ones a month+ old during the truing up process - but anyhoo its a pic - Ill have to shoot some more once its painted and finished.
Charliewood
PostPosted: Mon May 14, 2007 7:01 am
I don't know much, but I know that on gym floors and bowling alleys it is usually applied with a lambswool mop instead of a brush.  I don't know how that would translate to a drum, maybe something like a small lambswool polishing mitt or pad.  Seems to me it should do pretty well.  My question would be whether it'll handle the heat produced by a top drum thickness sander.
PostPosted: Mon May 14, 2007 7:23 am
If I were you I would ditch the finish idea, and wrap the drum is a hard rubber of some sort - I used auto gasket material from princess auto here in Canada, and contact cemented it to the drum - it helps cushion the paper just enough to help prolong the paper's life. My .02$
PostPosted: Mon May 14, 2007 8:22 am
Waddy -
Thats exactly what I was worried about, although the SN article just slapped about the idea of applying finish pretty loosely... so perhaps its not too terribly much of a concern,??!!??
I dunno mabye someone who defiitely does will chime in
Tony - great idea!!! Unfortunately.... I live in a place where sourcing things like that is a bit complicated sometimes,{too say the least}
but I will definitely consider what you say... its definitely less complicated a method than applying finish and truing the drum again...
Cheers for the input guys.... anyone else?
Charliewood
PostPosted: Mon May 14, 2007 8:30 am
try them on the web .. www.princessauto.com, or maybe a local auto supply .. at princess, it was like 12 bucks for a piece 2x3 ft.
PostPosted: Mon May 14, 2007 9:01 am
Do you have a photo of your finished drum Tony?
Charliewood
PostPosted: Mon May 14, 2007 10:43 pm
one aspect of any finish you apply that you need to consider is its behavior when it gets hot. the drum will generate a bit of heat, more or less depending upon how hard you push it. if the finish were to soften and slip around it might cause problems.
PostPosted: Tue May 15, 2007 1:59 am
That's something to consider if you use contact cement and cover with other material as well.  I have seen contact cement fail just sitting in the sun for a short time.  I suppose it depends on the cement you use too.  Why don't you use z-poxy?  It should be pretty hard, and be easy to level out.
PostPosted: Tue May 15, 2007 4:24 am
Im still in the consideration stage definitely Waddy, so anything is a possibility at this point...
Cheers for the info/tips
Charliewood
PostPosted: Tue May 15, 2007 4:36 am
Charlie, I'd either just leave it once trued up or just a thin coat or two of shellac to seal it. Looks like the drum is birch plywood eh? all those pieces glued together should be pretty stable I think and if it's in your shop (don't know if the shop will be humidity controlled) than it should be fine.
PostPosted: Tue May 15, 2007 5:50 am
Actually Rod the ends are 3/4" bb but the 18 or so disks in between them are 3/4"mdf - but all the same I dont think there will be stability issues, as I have heard from others who say thier mdf drums have held up for years..
Heck I dont even mind if I have to re-true them up slightly once a year or so.
Thanks for the input Rod
Charliewood
PostPosted: Tue May 15, 2007 6:08 am
Charlie, are you gonna use hook & loop paper or stick-on paper?  That could make a difference.  If you use stick-on, sealing would be a good idea.  I think it would make the paper stick better.  That MDF edge is pretty porous, and cleaning glue off could be a mess. I think, I would seal it no matter what.  You will get stuff to stick to it better, IMO.
PostPosted: Tue May 15, 2007 12:00 pm
What about a coating of JB Weld? You can sand it smooth afterwards. It might take a bit, but I'm sure you can get there.
The above suggestion is offered on 6 hrs or sleep over two days. Use at your own risk.
PostPosted: Tue May 15, 2007 2:12 pm
I have a 4" white pine drum on mine and I didn't put any finish on it. I did cover it with a velcro material, though, so I use velcro backed paper. In use for two years and no problems at all.
PostPosted: Tue May 15, 2007 3:24 pm
I use water based Varathane floor finish on all my jigs & it seems to work great... No problem with it softening up with a little heat on the sanding drum.
PostPosted: Wed May 16, 2007 4:11 am
The hard bb disks on the ends of the drum
{although not yet completed in the picture shown}
have locking wedges in them - the ends of the sandpaper are inserted into these wedge cavities, then the wedge is inserted and tightened down
{theres a threaded insert in the bottom of the wedge cavity}
this locks the sandpaper in place without adhesives of any type.
So for this matter... the drum could probably left bare?
Mabye someone can comment having the extra info
I should have stated this earlier..
Charliewood
PostPosted: Wed May 16, 2007 6:42 am
I think, under those circumstances, it would be fine as long as it doesn't get wet or live in a very damp or dry environment.
PostPosted: Wed May 16, 2007 11:53 pm
Charlie, I would think the idea of applying finish to the drum is to seal it and help prevent it changing shape from humidity changes.
I think I would just use some 2lb cut shellac and let is soak in a little, maybe just rag it on for a nice thin coat. That should be enough to give it a seal and then the paper being wrapped around it would help even further.
Or, you could just skip that step and only do it if it does become a problem later.
PostPosted: Thu May 17, 2007 4:16 am
Thanks for all the advice guys - I think I will do what you say Dave - its just easy and I really have alot of extra projects on the go now, that could use the attention I would end up giving to this sander..
Charliewood
